R50/53 Compression test results, opinions?
Old Jun 13, 2014 | 09:33 AM
Hunt3r's Avatar
Hunt3r
Performed a compression test last night. Just a single pulse per, probably should have tested a couple times.
Cyl #1: 140 psi
Cyl #2: 140 psi
Cyl #3: 145 psi
Cyl #4: 155 psi
Car has 143k miles. Plugs looked good and from what I could see down the spark plug tube cylinders looked pretty good. I'd say from what I've read on here my compression results are pretty good. Opinions?
Old Jun 13, 2014 | 10:36 AM
ZippyNH's Avatar
ZippyNH
Depends on the type of car.....r50 or r53 or r52 s or non s?
A r50 has higher compression pistions than a r53....so results are very different.
Old Jun 13, 2014 | 10:46 AM
Hunt3r's Avatar
Hunt3r
My bad, thought I had posted that info too. It's an r53.
Old Jun 13, 2014 | 04:31 PM
Da_Ghost's Avatar
Da_Ghost
According to the Bentley manual, it's between 131 and 196 psi with a difference of 7 psi between cylinders. Pretty vague to be honest about the margin, but who am I to argue with a book!
So when going "by the book", you're in the correct range, but the difference is off. But going by the 10% difference rule, you're fine. Your highest being 155, so 15.5 psi difference, which means that the lowest one must be higher than 139.5 psi.
KristaMcCoy
Sep 12, 2015 05:37 PM
Richard Kellstrom
Sep 4, 2015 07:21 PM
Sep 3, 2015 02:06 PM
