Noisy yokohamas after 15000 miles
Old Jun 7, 2014 | 12:05 PM
Cruzer214's Avatar
Cruzer214
After about 15000 miles on my envigors the rear tires starting getting noisy because they are wearing on the inside of tire due to the camber minis have. My dealer rotated them to the front and the noise is twice as loud then before. If any of you had this same issue and rotated to front will the tires quiet down when they wear in? Btw, my dealer told me most people need new tires just after 20000 miles! Also, I don't drive like I stole it and most of the miles are highway.
Sent from my iPad using NAMotoring
Old Jun 7, 2014 | 12:28 PM
dongood's Avatar
dongood
This is the very reason I rotate my tires, front to rear, every 3k miles.
Not much you can do now, something to keep in mind for the next set.
I get around 30-35k miles on my Dunlop Drizzas.
Old Jun 7, 2014 | 08:36 PM
bmwr606's Avatar
bmwr606
i rotate every 4000 miles on my all4, when i change oil/filter
dealer does every 8000 and i do one 1/2 way between
on the all4, i cross rears to front and fronts straight back to ther rear
Old Jun 7, 2014 | 09:40 PM
Joeygonz's Avatar
Joeygonz
Likewise, I have mine rotated and balanced every 3.5K miles since the very beginning. I am running an all-season Michelin AS/3 with 50K warranty. Planning on to see how far I could go with this kind of discipline. Last set of tires I had (from a different car), made it 80K miles which were religiously rotated and balanced every 5K miles.
I drive 120 miles a day with 90% freeway driving against rush hour and only deal with 4 traffic lights combined. Cruising speed at an average of 75 mph that uses 36.XX mpgs.
Old Jun 8, 2014 | 06:18 AM
jcauseyfd's Avatar
jcauseyfd
Eventually you should see some reduction in the noise now that they are rotated. That said, since you waited so long, it may be a while before you can tell.
When I had my S.Drives, the road noise started to get pretty bad at about 18,000 miles. Your Envigors should be able to last a whole lot longer though, so I wouldn't expect significant noise for some time if you can get the damage done from the lack of rotations worked out.
As others have noted, rotate every 5k miles or so.
Also, I'd find a different source for tires and tire work than the dealer.
bigramdizzle
Aug 6, 2019 09:19 PM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
phrza81
Oct 10, 2015 11:37 PM
ltjpunk7
Sep 6, 2015 07:32 AM
TBRoye
R55 :: Clubman Talk (2008+)
Aug 24, 2015 08:41 PM
