R50/53 Help!! knocking noise and lots of oil or somethin
Old May 26, 2014 | 12:00 PM
umberto's Avatar
umberto
Help ....my '04 MC 135,000 mi runs fine but yesterday it began making just one knock noise, not loud, whenever I would tap on the gas ....sounds like from the front passenger side ...today I opened the bonnet ( NO it is a hood, dammit!) ...if you are standing at the front of the car, attached to the left of the engine there is an aluminum dome shaped component where oil or something is pooling at the base of this component which sits on red metal ( my car is chili red) This has a grounding wire leading from the top of this component to a bolt on the red metal where the component sits.
the noise sounds like when an engine mount went on one of my previous cars but what is this oily stuff and what is the component, so when I bring it in to my mechanic I don't sound totally clueless,,,,,,
thanks
Old May 26, 2014 | 12:07 PM
hypnotiqphil's Avatar
hypnotiqphil
is this what it looks like?
If thats it, its common for when this motor mount breaks it will leak oil from it. You just need to replace it.
Old May 26, 2014 | 12:25 PM
umberto's Avatar
umberto
Yup...so I was right, sort of...I was guessing engine mount but did not recognize what it would look like.... I was picturing it being lower down ..... Is this a type of repair my local mechanic who has worked on some minis can do, or would it be better to bring it to my inconveniently located one hour away place that specializes in minis?
Old May 26, 2014 | 12:53 PM
hypnotiqphil
heres a good how to do it, it takes no longer then one hour, honestly i would buy the part and do it myself but that depends on how you want to do it.
heres where you can buy it
http://www.waymotorworks.com/afterma...unt-04-06.html
Old May 26, 2014 | 06:18 PM
minsanity's Avatar
minsanity
Never go back to OE. Replace w/ VibraTechnics instead.
http://www.vibra-technics.com/mini_b...53_12_03_07_06
Old May 26, 2014 | 08:43 PM
shrevemini's Avatar
shrevemini
Top Answer: 1
Yeah just do it youself. It not hard to do, if you have some tools.
Melvinyip
Apr 17, 2020 09:28 AM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
silence2-38554
Nov 12, 2015 09:39 AM
elightbo
Aug 17, 2015 01:50 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
