R50/53 Do I need new shocks
Old May 21, 2014 | 11:47 AM
xpcdoojk's Avatar
xpcdoojk
I have a 2003 MINI Cooper S, with 72,000 miles on it. I have had it since it was new. 11 years 2 months and 4 days, but who is counting.
I am about to order my fifth set of tires. I have the 17" S lite wheels and currently Pirelli Run Flat max performance summer tires. The wear on this set has not been very even, although I thought the ride was the most comfortable of the 3 sets of run flats I have had on the car. The one set of non run flats I ran a BF Goodrich set (which were just squirrelly on grooves in the road) I hated. Plus I like having the security of being able to go where I need to if I have a flat. (which I haven't in 72,000 miles). I do not track the car, but I do love to go around corners.
Should I replace the shocks and do an alignment before I install (or while) new tires. Currently looking at trying Bridgestone Potenza runflats. If I do need shocks what is the right shock for the sport suspension?
Thanks in advance.
jc
Old May 21, 2014 | 01:24 PM
Fly'n Brick's Avatar
Fly'n Brick
Strongly recommend KONI FSD dampers. They are on super sale now at motoringwerks.com for near half price. Also, while the wee laddie is on the lift is a good time to add a 22 MM rear sway bar. You won't believe what a difference those two mods will make to handling. They are hands down the best mods for the money you can make on a MINI.
PS: Yea, at 72K miles you probably do need to replace them.
Old May 21, 2014 | 03:31 PM
4130's Avatar
4130
I recommend checking your front wheel control arm bushings with a tire kick test. If they move, the bushings are likely shot and could be the source of the uneven tire wear. At least, that was my experience.
For the record, I have almost 110K on my car and although I bought it used at about 57K, I'm pretty sure I'm on original shocks and definitely stock. My mechanic told me not to bother changing the shocks unless a problem developed. I'm sure the Konis are great, just check the bushings first.
Old May 21, 2014 | 05:04 PM
Fly'n Brick
+1
Didn't give that a thought, just got all excited about new dampers and RSB.
Old May 28, 2014 | 02:42 PM
xpcdoojk's Avatar
xpcdoojk
I have read the Konis make for a very stiff ride. How are the Bilsteins?
Any thoughts?
jc
Old May 28, 2014 | 03:44 PM
ZippyNH's Avatar
ZippyNH
Any thoughts?
jc
Koni fsd's are the "comfort with performance" strut/shock....koni yellow struts are performance, and stiff...bilsteins are pretty rare on a mini....a few reports said they were VERY STIFF....
my guess...you control arm bushings are likely worn..Polly ones will last forever, rubber about 36-75,000 miles....when worn they let the front wander a bit....thus the tramlining...and struts at 70k, 10+ years are pretty gone too....
Old May 29, 2014 | 08:39 AM
xpcdoojk's Avatar
xpcdoojk
So consensus is that I need this stuff from motoringwerks.com?
MINI Cooper R50/R52/R53 Koni FSD Shocks
MINI Cooper Alta Adjustable Rear Sway Bars-MINI Cooper Alta Rear Sway Bar 22mm Adj
Old May 29, 2014 | 08:40 AM
xpcdoojk's Avatar
xpcdoojk
anything else?
Old May 29, 2014 | 11:36 AM
mini on's Avatar
mini on
Did mine at 60k and wish I did it sooner.
Old May 29, 2014 | 01:42 PM
Fly'n Brick
Ditto except I wish I done mine sooner than him.
Old May 29, 2014 | 02:06 PM
Dozuki01's Avatar
Dozuki01
Control Arm bushing too!
Old May 29, 2014 | 02:34 PM
xpcdoojk's Avatar
xpcdoojk
Which ones on the control arm bushing? Any other little bits that I am going to say, "damn I need that too"?
MINI Cooper Eibach Rear Control Arms
MINI Cooper Alta Adjustable Rear Control Arms
MINI Cooper NM Eng Titatium Adjustable Control Arms
MINI Cooper Hotchkis H-Sport 2-Piece Rear Control Arms
Old May 29, 2014 | 03:12 PM
ZippyNH's Avatar
ZippyNH
None of the above....
They can be bought pre-pressed or you can reuse yours....they are kinda a pain to change...front end...where the front subframe and the main part of the body meets on the underside of the car...about a foot back or so from the wheels....these are almost certainly bad...those and struts...the rear sway bar is optional, but a nice change IMO.
Old May 30, 2014 | 07:06 PM
lawjdc's Avatar
lawjdc
I also did the Koni FSD shocks and the Alta 22 mm rear sway bar to my 2005 Mini S. For good measure I mounted some Bridgestone RE-11A tires on stock rims.
Now my Mini is more fun to drive around town than the Porsche. Seriously!!!
Old May 30, 2014 | 07:16 PM
minsanity's Avatar
minsanity
Go Powerflex (not OEM) for control arm & sway bar bushings. Get new Genuine or Lemforder ball joints & strut mounts.
http://www.waymotorworks.com/powerfl...shing-kit.html
RobbyD
Jan 29, 2019 01:22 PM
pahg
Oct 5, 2015 11:50 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
Emnotek
Sep 29, 2015 07:37 AM
