R60 R60 ALL4 dyno limitations?
Are there any limitations when going to dyno the ALL4? Meaning... are we limited to a linked Dynojet or mustang dyno? I know with Haldex awd cars, you need one of those type dynos or are required to disconnect the Haldex when on the dyno. The ALL4 has a electromagnetic center differential and would like to know if the limitations are similar to the Haldex?
Thanks!
Thanks!
Hes never dynoed a Mini ALL4 and isn't too familiar with the AWD system but thinks its similar to Haldex from what hes seen. The other way to be safe is to disconnect the driveshaft... Audi's do that or pull the plug on the Haldex prior to dyno.
I think I get what you're talking about. I didn't get it before. I don't really know enough technical info about dynos to say for sure one way or the other. The Haldex is the system that is primarily FWD until it detects wheel slippage and then sends torque to the rear wheels right? I would have to believe that any dyno that is capable of dynoing a STI/Evo would work fine for dynoing an all4 since if the rollers aren't linked you could have the potential of frying the center diff in the STI/EVO. But again I don't know for sure. But if you're in the NJ area aren't there tons of places that tune VWs that could dyno the car?
There are only a select few places in NJ that have the specific dynos.
An answer direct from GKN driveline
Heres the response I got from the manufacturers (GKN Driveline) of our AWD system.
"I’m glad you asked this ! Because the Mini Countryman is an on-demand AWD system you either a) Have to use linked rolls or, b) physically disconnect the propshaft and test in 2WD. If you test it on unlinked rolls the coupling will quickly reach its maximum operating temperature as if the front wheels were always on ice and the rears always with grip. The software will open the coupling to protect it but the resulting huge speed difference across the clutch is still not something you want to do. Don’t just disable the AWD with a fuse or connector disconnect because the excessive speed difference problem remains.
If you can’t do (a) and use (b) instead (as most people do) you will probably throw all sorts of ESC/ABS and AWD codes that you may have to clear yourself once you reconnect the system after using the dyno."
Enough said for me!! I will be disconnecting the propshaft.
Sep 18, 2015 12:45 PM
Tires, Wheels & Brakes
Sep 14, 2015 11:34 AM
