R50/53 How to Access Seat Belt - '05 Mini Cooper S
Old Apr 21, 2014 | 06:15 PM
GPMiniMoo's Avatar
GPMiniMoo
I am trying to open/access the seat belt panel where it gets in the tensioner. Before I break anything, has anyone done this before? I am a new member so can someone post instructions on how to open and access the seat belt panel please.
The issue I am having is that my seat belt gets soaking wet when it rains. I can't see anything from the outside of the car where the water is leaking from, so I would like to be able to open the panel inside then pour water to see where the leak is coming from.
Thank you in advance.
Old Apr 23, 2014 | 11:18 AM
GPMiniMoo's Avatar
GPMiniMoo
Reposting for help.
Old Apr 23, 2014 | 11:56 AM
ZippyNH's Avatar
ZippyNH
just a WAG...
but guessing you
1- must have a sunroof....and
2- the drain on it might be disconnected or plugged....leading it to overflow...
I would look for info on the sunroof drains....and check them.
Old Apr 23, 2014 | 11:59 AM
GPMiniMoo's Avatar
GPMiniMoo
Thanks but I don't have a sunroof.
Old Apr 23, 2014 | 12:41 PM
ZippyNH's Avatar
ZippyNH
Next I would look at the window seal....bet it is out of adjustment...might be noisy......water is streaming back past the glass....
Window should be TIGHT against glass...but if the door is a bit out of sack...a tiny bit...you have a gap...air...water comes in...there is a vent in the back....so bam....wet seat belt...
That's my 2nd guess!!
Old Apr 23, 2014 | 01:56 PM
Capt_bj's Avatar
Capt_bj
do your windows "do the dip" when you open the doors?
What part of the belt is wet? A picture or (crude) drawing might help. ... Is the exposed part wet, or what comes off the reel, or both? Any wet carpet?
This might sound silly .. BUT: you know those car washes where you can stay in your car?
Old Apr 23, 2014 | 02:16 PM
GPMiniMoo's Avatar
GPMiniMoo
Yes the windows are perfect. The inner part of the belt, the part that's in the panel that's retracted is the only wet part. That's why I need to open up the side panel so I can check where the water is leaking from. Any tips on how to access the side/seat belt panel will help.
Dec 23, 2015 10:36 AM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
