Rebuild or replace engine
Old Apr 19, 2014 | 06:00 PM
joes68340s's Avatar
joes68340s
Well its looking more likely that I am burning oil and just wondering whats popular new motor or rebuild. Its to bad I just got the car set up where I like it and now, Its my wifes car and only has 75,000 miles. I havent looked any further into the problem because I cant find someone I trust to work on it. everytime I take it in they work on something else and not the problem. Is it more common for the topend valves to go bad or lower rings.
Old Apr 19, 2014 | 06:21 PM
jamez's Avatar
jamez
I ended up doing both.
The first rebuild didn't go right so I had the dealer install a new JCW engine kit
Be very careful with who you choose if you decide to rebuild it; it's a lost art, and not everyone has the skills to do it right.
If you are in Canada, I have a spare W11 for an R53 for sale cheaper than importing one.
Old Apr 19, 2014 | 06:35 PM
AZdsrt's Avatar
AZdsrt
How much oil are you burning? Mini's in general are known to be oil hungry. As my dad once told me (a LONG time ago), the cost of a new engine buys a LOT of oil. In other words, would you rather spend $6k now, or $5 every few weeks.
Old Apr 19, 2014 | 06:37 PM
joes68340s's Avatar
joes68340s
Thats the problem there arent any machine shops around and I dont know what a dealer can do for me. what options are there for an 07 S model.
Old Apr 20, 2014 | 06:55 AM
zrickety's Avatar
zrickety
If it's just oil consumption, I would do the rebuild myself assuming you own some tools. Disassemble to remove the pistons, deglaze the cyldiners, replace the rings, all seals and gaskets. Maybe the timing chain components depending on condition. A rebuilt short block is not a bad idea, but there is a huge cost difference. Any reputable shop can do this, but the dealer would be the most expensive.
Old Apr 20, 2014 | 07:55 AM
ZippyNH's Avatar
ZippyNH
Unless it us knocking....
Drive it till it blows....
Many mini's burn about 1 quart per 1000 miles, and some go 2x that.....
If it is a s mini...I would look at the turbo...seals can leak...causing oil consumption.....as can pcv issues....
You can get a factory rebuilt motor or a used one.....doing a diy rebuild or paying someone to do it IMO is iffy...the parts from mini are $$$....so generally not doable on a cost basis....
Old Apr 24, 2014 | 02:29 PM
joes68340s's Avatar
joes68340s
Its definatly burning oil. Whats a quick method for checking turbo seals. I just replaced the valve cover for oil consumption because there is a noticeable amount of oil in the turbo inlet an hoses. So much for the valve cover. Still lots of oil in hoses.
silence2-38554
Nov 12, 2015 09:39 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
PSIChocolate
Aug 13, 2015 12:46 PM
wind715
Aug 11, 2015 07:56 AM
calebmil
Aug 7, 2015 05:54 AM
