FS:: Alta Mini cooper accessport
Old Apr 14, 2014 | 06:03 AM
djjeffyt's Avatar
djjeffyt
Price: $700
Location (Region): West
Unit is un-married and ready for install (see photos)
The ALTA AccessPORT allows you to unlock your vehicle's hidden power
Simply plug into your OBD diagnostics port, and in minutes you can change the ECU programing to give you an additional 20-40 Wheel Horsepower. No cutting, wiring, or other such modifications, simply plug-and-play.
ALTA Custom Tuned Staged Maps are included with every purchase that will give as much as 40 Wheel Horsepower and as much as 100 ft/lbs Wheel Torque gain, over stock levels. Also gives you the ability to easily change maps as you upgrade to new parts for your car. With the ALTA AccessPORT, the possibilities are endless!
The ALTA AccessPORT is so much more than an ECU flash device that makes Horsepower. With its gauge functionality, datalogging capabilities, and its ability to be an OBDII Scan-tool, the ALTA AccessPORT is a perfect "all in one" tuning tool that anyone can use. The ALTA AccessPORT is backed with tons of support and updated mapping as you upgrade and install new parts to your MINI!
Attached Thumbnails Alta Mini cooper accessport-20140410_144448.jpg   Alta Mini cooper accessport-20140411_073631.jpg   Alta Mini cooper accessport-dyno_stage_r56stage1.jpg
Old Apr 30, 2014 | 10:56 AM
bennys8's Avatar
bennys8
Is this sold already?
Old Apr 30, 2014 | 12:45 PM
djjeffyt's Avatar
djjeffyt
Yes sold :( you were two days to late
jrezzo
Aug 9, 2015 10:32 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
