Suspension coilover help
Old Apr 9, 2014 | 09:51 AM
PA-MCS's Avatar
PA-MCS
coilover help
I cant decide....I was deadest on Megan or BC's because of the camber plates. But now im looking at the ST coilovers.. The suspension source has the ST's for 849 or the ST XTA with camber plates for $1317. Has anyone tried the one with camber plates. but if I get the regular ST coilovers I still need to get camber plates and that's another $400-$500
Old Apr 9, 2014 | 10:08 AM
elsenordave's Avatar
elsenordave
I enjoy my my BC easy set up.
Old Apr 9, 2014 | 10:18 AM
TheSuspensionSource's Avatar
TheSuspensionSource
Don't think you will find anyone with the XTA's yet. They have not shipped yet. However if you did not want to wait for the XTA's you can add Eibach camber plates, just PM me for price.
Whether or not you need camber plates is always a fairly intense opinion.
Old Apr 9, 2014 | 10:37 AM
PA-MCS's Avatar
PA-MCS
Im guessing they come with their own brand of camber plates? When do you think they will start shipping out?? I don't think I will need them as far as adjustments go. I think my stock plates have some age so might as well buy new
Old Apr 9, 2014 | 10:45 AM
TheSuspensionSource
Next week is the ETA for the shipment. The camber plates are made by ST/KW. The "standard" ST coilovers are designed to use OE top mounts, using an camber plate is a matter of opinion. I have customers running with OE top mounts and without. Just depends on what you use the car for and how much adjustment you need.
Old Apr 10, 2014 | 01:37 PM
PA-MCS's Avatar
PA-MCS
so the ST XTA are adjustable like the KW V2's?? IF so hold my order I just order a set of the standard ST coilovers....eeeks!!
Old Apr 10, 2014 | 01:48 PM
TheSuspensionSource
That is correct. The XTA is very similar to the KW V2 coilover. The XTA is the same galvanized steel housing unlike the V2s stainless steel housing. And of course the 5 year warranty also applies to the XTA.
If you need the adjustments of rebound then I would hold out for the XTA, if not the standard ST coilover kit works perfectly fine. You can always add camber plates later if you feel you need the camber adjustment.
Old Apr 10, 2014 | 02:10 PM
PA-MCS's Avatar
PA-MCS
IM sent
RIchard Nguyen
Sep 14, 2016 11:43 AM
Keet
Suspension
Aug 30, 2016 03:46 PM
sssevita
Mar 20, 2016 06:24 AM
CooperSharp
Oct 12, 2015 09:21 AM
gnhovis
Sep 28, 2015 10:56 AM
