R56 LED Replacements need some help
Old Mar 26, 2014 | 11:15 AM
Dfrontiera's Avatar
Dfrontiera
Hello fellow R56 lovers...
I'm in the process of replacing all my interior lights with LED replacements. The problem I'm having however is figuring out if the under the dash lights (below the pedals and glove box) are the same as the lights that go under the door (Step lights). My Mini is the 2008 R56 Non S version. I've been searching the site and internet for hours with no straight answer. Can anyone confirm??
Thanks!!
-D
Old Mar 26, 2014 | 11:20 AM
Here is our Ziza Led kit for the R56 up to 8/2010, On the install PDF attached to each Ziza has a step by step. You can check at the under dash step which shows the light socket mount. Page 10 on the PDF
R56 up to 8/2010
http://www.ecstuning.com/Search/SiteSearch/ES2568957/
And click here for the PDF R56 -8/2010
Thanks and hope that helps
Old Mar 26, 2014 | 12:14 PM
Dfrontiera's Avatar
Dfrontiera
Thanks for the quick reply. Do you happen to have different color packages? I have a particular LED color Scheme I'd like to have. For example I want the Dome to be blue, the map lights and glove box white and the rest Red.
Old Mar 26, 2014 | 12:32 PM
Your welcome. We have them all in a white ( has a little tiny bit of blue ). Which looks good on all interiors. Newer MINIs have factory mood lighting which changes colors ( more color on the 8/2010+ which get pretty bright, so the white complements it well.
Old Apr 6, 2014 | 06:07 PM
ice.berg's Avatar
ice.berg
Simple answer to it all is all of the interior lights are the same besides the glove box which is a W5W. Otherwise they are all 194 or T10. A good site to get colored ones is superbrightleds.com or else through amazon (though these can be very hit or miss) Good Luck!
HCClubbie47
R55 :: Clubman Talk (2008+)
Aug 24, 2015 02:16 PM
Lschneider
Aug 21, 2015 02:21 AM
PSIChocolate
Aug 13, 2015 12:46 PM
