FS:: Custom catch can internally baffled + filtered
Old Feb 12, 2014 | 11:46 AM
daonlyillwiz's Avatar
daonlyillwiz
Price: $200
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57, R58, R59, R60, Classic Mini
Item Condition: Brand New
Hello all, up for sale are 2 brand new catch cans that were custom made. The first features 2 fittings, one inlet and one outlet. The second features 3 fittings, 2 -8an fittings that go to the valve cover and 1 -10an fitting that goes to the intake pipe. Basically the fitting coming off the valve cover goes in the top port and the fitting on the side goes into the intake pipe. The can is internally baffeled AND has a coalescing filter to catch all the oil vapors getting sucked out of the valve cover and condense them to liquid where they settle on the bottom of the can. There is also a sight glass on the front so you can see the level and a drain valve. This is hand made tig welded out of 1/8" wall 6061 aluminum extrusion...not sheet metal. Can weighs about 1 pound. and uses -8 AN fittings.
Price for the first can is 200, Price for the second can is 220.
Attached Thumbnails Custom catch can internally baffled + filtered-cc1_side.jpg   Custom catch can internally baffled + filtered-cc12.jpg
Old Mar 7, 2014 | 08:56 AM
daonlyillwiz
bump
molala
Oct 2, 2015 01:53 PM
OutMotoring
Sep 8, 2015 06:27 AM
Sep 3, 2015 10:29 AM
Sep 2, 2015 11:15 AM
Sep 1, 2015 04:39 PM
