R50/53 Door Panel - How to Remove Trim Pieces
Old Jan 27, 2014 | 01:15 AM
jamanta's Avatar
jamanta
Hi all, I'm thinking about customizing my Mini's interior and I have a question. Can all the gray pieces (refer to the pic) on the door be removed without actually removing the complete door panel?
I'm thinking about doing a vinyl wrap. thanks!
Old Jan 27, 2014 | 05:30 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I'm fairly certain those parts are attached to the door card using heat melted rivets on the back. Door card comes off easy if you want to check.
Old Jan 27, 2014 | 07:16 AM
buzzsaw's Avatar
buzzsaw
If you go to the site below under the DIY section there is a Youtube video showing how to remove the door panel. There are numerous links pertaining to the door that may also be helpful. Good luck.
Old Jan 27, 2014 | 02:46 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
You may get a better idea if you can easily separate the handle/trim from the panel itself once you have removed the panel. Sorry not to be more specific than that! Removing the MINI's door panel is a snap though!
Mark/Pelican Parts
888.280.7799 | 6am - 5pm PST
sevin
May 2, 2026 06:11 AM
kazyn
Oct 25, 2019 02:34 PM
mrjolliff
Oct 9, 2015 05:55 AM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
