R61 :: Paceman Talk R61 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
R61 Breaking in Cold weather
Old Jan 26, 2014 | 06:51 AM
Quixter's Avatar
Quixter
This is my first Mini and my first car I have experienced this with. Sometimes when I brake when there's a lot of snow\ice out the brakes make a sort of grinding noise. The braking motion itself seems rough. Is this normal? I've never had this in other vehicles I've own.
Old Jan 26, 2014 | 07:11 AM
JAB 67's Avatar
JAB 67
Abs?
Old Jan 26, 2014 | 07:20 AM
Angib's Avatar
Angib
Does it mostly happen when you haven't driven the car for a couple of days and the last drive was wet/salty? Mini discs rust quite quickly and if you don't drive the car for a few days, the first few times you brake, you may be wiping surface rust off the discs which produces a rubbing/grating sound. If so, very normal, at least for Minis, and not something to be concerned about.
You can check, if you remember, by looking at the discs through the wheel spokes before setting off when the surface rust can be clearly seen.
Old Jan 26, 2014 | 07:30 AM
cristo's Avatar
cristo
Alliance Member
gravelly chattering noise and feel when braking on snow/ice? ABS.
Old Jan 26, 2014 | 08:00 AM
ZippyNH's Avatar
ZippyNH
Which tire option did you get? Some folks take delivery of their cars on summer tires....very hard rubber in the cold....grips very poorly below 40°f....
Also as noted....the rotors do rust very fast...so a bit of extra noise for the first couple stops till you polish off the corrosion.....
Old Jan 26, 2014 | 04:51 PM
Quixter's Avatar
Quixter
Thanks, Have only noticed it in the winter when it's very cold. I do have the stock all season tires. Cristo described it better than me. I think this is the first car I have had with ABS. Thanks for all the response.
rbarakat
Oct 3, 2015 11:08 PM
shorenetworks
Sep 20, 2015 08:46 AM
Gen1Parts
Sep 7, 2015 03:50 PM
Gen1Parts
Sep 7, 2015 01:37 PM
dandw2
Sep 7, 2015 11:14 AM
