R56 2012 MCH service indicator
Old Jan 24, 2014 | 05:04 PM
breyfogle's Avatar
breyfogle
At startup, the service indicator has begun to tell me the brake fluid needs service. Is this service time based, miles based, that I can put off awhile or does it indicate a failure of some kind that needs attention ?
Old Jan 24, 2014 | 06:04 PM
nine5raptor's Avatar
nine5raptor
Its every 2 years I believe
Sent from my XT926 using NAMotoring
Old Jan 25, 2014 | 05:45 AM
zrickety's Avatar
zrickety
Yeah it's on a timer. You can safely reset it, wait until you need actual brake service.
Old Jan 25, 2014 | 12:24 PM
RiskyBusiness's Avatar
RiskyBusiness
But the service is free, why not do it?
Old Jan 25, 2014 | 05:30 PM
Slave to Felines's Avatar
Slave to Felines
If you let it go for too long, and do that regularly, you can wind up with rust on the inside of your brake system. That's kind of expensive to fix, as you can imagine.
In the short term, brake fluid with water in it will boil at a much lower temperature than fresh brake fluid. Which means it is easier to overcook your brakes so that the pedal goes straight to the floor. (Not a happy thing; I've experienced it in other cars before.)
If you're still in the free maintenance period, I figure it's a no-brainer to have the dealer do it for you for free. If you're not, I'd still get it done sooner rather than later...
Kimolaoha
Jul 5, 2023 01:04 PM
R60abq
R60/R61 Stock Problems/Issues
Jun 6, 2017 05:15 PM
FrostyFox
Oct 28, 2015 02:06 PM
bjcarter2
Aug 31, 2015 04:03 PM
gknorr
Aug 24, 2015 06:39 PM
