R59 just starting to mod my r59 please help
Old Jan 13, 2014 | 02:40 PM
minitatonka's Avatar
minitatonka
Hello fellow roadsters. I wanted to say Hi and also have a few questions for you guys.
I want to start modding my roadster s and was thinking of starting with the NM air charge pipe and the NM discharge pipe. Then also getting the Forge alloy intercooler. Possibly the NM oil catch can too.
Do you guys think is a good starting point or should i start in another direction?
Thank you everyone and thank you for your replies.
Old Jan 13, 2014 | 02:57 PM
jkapinos's Avatar
jkapinos
You should add to your list the NM engine torque arm insert. And if you have an N18 the BMS JB+ is one of the best mods.
Old Jan 13, 2014 | 03:20 PM
minitatonka
how do i know if i have an n18 engine? I looked around the internet and couldn't figure it out is it the s model? which I have. Also, what is BMS JB+? And what does a torque arm insert do? Sorry the multiple questions just want to understand. Also thank you for your reply
Old Jan 13, 2014 | 03:43 PM
jkapinos's Avatar
jkapinos
If your Roadster is a MCS you have a N18 motor. You would need to have a 2012 JCW to not have one. The torque arm insert stops your engine from moving around. Helps with shifting and will give a better feel, also it's cheap. The BMS JB+ is a tune that plugs into your MAF and tricks your engine into having more boost, HP, and torque
Old Jan 13, 2014 | 07:56 PM
minitatonka
Ok thanks jkapinos. I will get the torque arm insert. with the BMS JB+ will that mess up the computer? and also what is a MAF. Thanks for all your help.
Old Jan 14, 2014 | 12:32 PM
KilmerPT's Avatar
KilmerPT
If you have a manual, I would recommend the BMS clutch stop. It's $10 and a great improvement from the stock clutch "play".
Attached Thumbnails just starting to mod my r59 please help-image-4267378375.jpg
Old Jan 15, 2014 | 04:38 AM
spiney's Avatar
spiney
MAF = Mass Air Flow sensor (http://en.wikipedia.org/wiki/Mass_flow_sensor). Measures the amount of air going into the engine so the computer can calculate how much fuel to inject.
The JB+ connects in-line in the wiring between this sensor and the computer.
Old Jan 15, 2014 | 06:45 PM
minitatonka
will the JB+ mess up the computer?
Old Jan 15, 2014 | 07:02 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Like jkapinos said the NM torque arm bushing is the perfect first mod.
http://www.waymotorworks.com/nm-engi...nt-insert.html
After that it will depend on your goals. Please feel free to give us a call and we'll work with you on putting together parts to fit what you want.
For power a Forge intercooler is a perfect start that won't void your warranty.
But for handling an Hsport Comp rear sway bar is the best bang for the buck.
Old Jan 15, 2014 | 07:06 PM
minitatonka
Thanks way motor works. So I was looking at my list of parts i want. I will get the torque arm insert and short throw clutch stop. Now, should I go with the NM oil catch or the x brace with those two?
Old Jan 17, 2014 | 04:00 PM
jkapinos's Avatar
jkapinos
The x brace will lessen ground clearance. Do you plan on lowering your Roadster? Also the Roadster is already pretty stiff, with the stock bracing. Most think a catch can on the N18 is not needed. I have one but have not installed it.
Old Jan 17, 2014 | 04:19 PM
minitatonka
thanks jkapinos. I am going to keep it at stock height. So then probably x brace 1st then oil catch can. what do you think of the AEM cai? they supposedly are making for the n18 enigne.
Old Jan 17, 2014 | 06:49 PM
jkapinos's Avatar
jkapinos
AEM makes very good products. My other car is a EVO X and many people with that car run them and are happy.
Old Apr 16, 2014 | 11:28 AM
silvrevo's Avatar
silvrevo
So your saying a '12 jcw roadster has the N14 motor?
Old Apr 16, 2014 | 01:52 PM
jkapinos's Avatar
jkapinos
Yes the 2012 JCW has a N14 motor. Check out Bluetoys post under R59 and see what he has done to his car. It should be helpful and it's a N14.
Old Jun 17, 2017 | 06:13 AM
BlueCooperS's Avatar
BlueCooperS
I'm looking at mods as well, and so far the engine brace and an upgraded intercooler look like good mods. Do aftermarket intake and exhaust systems do much on an N18 engine? I have an automatic, BTW.
Old Jun 17, 2017 | 06:15 AM
BlueCooperS
I have the Hsport hollow sway bar on my R53. Great mod. :D
Old Jun 18, 2017 | 02:46 PM
WayMotorWorks
Vendor
Save your money as intakes and exh just don't make power as they are more for sound.
If you want power do the intercooler first, and then we can do a tune for you as those will be the best bang for the buck mods for you.
Old Nov 13, 2017 | 01:27 AM
bongshi4's Avatar
bongshi4
Hi, I also own R59s, and as recommended by many others from here, I have JB+ and NM Torque arm insert on my car.
Dude, with NM TAI, your car will be totally different one when you put it on sport mod, and try to accelerate when you are stopped. It shoots out without any hesitation.
Here is a video I uploaded on youtube for idling engine. You may not see the big difference from the video, but for sure it's worth of money.
Old Jan 1, 2018 | 01:20 AM
blue al's Avatar
blue al
Will all facelift intercoolers fit a 2011/2 n14 jcw roadster
Seems a lot are sold as pre or upto 2010 (assuming general N18 upgrade)
I'm keeping my eye out for a second hand one and have already missed out on a forge and evolve, if I miss out by mid summer I might end up with something Unbranded from China
I'm looking to buy cheap in this area and support with a aquamist hfs4,
My rationale being this will give a better bang for buck than a top level intercooler and perhaps no budget left even for a Point and squirt kit
Old Jan 2, 2018 | 02:26 AM
spiney's Avatar
spiney
There's a bit different (extra) structure behind the front bumper on the facelift/LCI cars (which all Roadsters are) and I'm not sure if intercoolers for pre-facelift cars will clear it all. I'm sure someone can help. You can also ask this on the R56 forum or a general second gen one, all the R55/6/7/8/9 cars are the same in this area.
sevin
May 2, 2026 06:11 AM
Aug 19, 2015 12:51 PM
Aug 19, 2015 12:34 PM
Aug 19, 2015 12:33 PM
