R50/53 Water Pump change.....easier
Old Jan 12, 2014 | 06:14 PM
Perry45's Avatar
Perry45
Hi all. I again had the famous thermostat housing leak, and decided that as I don't want to waste another two gallons of anti-freeze and decided to tackle the Water pump as well.
I read several write ups on this and it looked pretty daunting.
I attacked the problem with zeal, and a cold six pack.
After placing the car in service mode, I detached the radiator hoses.
Removing the Intercooler I could loosen the throttle body and I had access to the water pump, easily removing it without removing anything else.
Then I made a Mistake.......
I thought it prudent to check the OIL level in the rear of the Super-charger. I removed the plug and oil started to run out! (No kidding right?, I didn't;t realize that you can't add or check the oil with the SC on the car.)
I was able to check and refill the FRONT side of the SC.
Reassembled the car and.....discovered that the NEW thermostat didn't seal properly.
Does anyone have a BETTER thermostat gasket recommendation?
Old Jan 12, 2014 | 06:52 PM
Perry45's Avatar
Perry45
PS. You can now purchase the Thermostat Gasket separately. FEL-PRO 35964. 12 Month warranty.
Old Jan 12, 2014 | 09:20 PM
ZippyNH's Avatar
ZippyNH
Problem is....
It is kinda part of the thermostat...
And thermosts go bad.... So just replacing both is usually a good idea...
And one tip...
Catch the used radiator fluid....if it is less than 3 years old...it can be reused....
But it is so cheap...I would toss it...and refill....the radiator fluid change/flush is THE most overlooked mantance item on a gen1 car...due every 36-48 months from the date of production......most ignore this...and end up with a plugged heater core...or worse...a head gasket issue.
elverado
Jan 18, 2022 02:51 AM
patsum
26
May 29, 2021 06:29 PM
Fordgt4
Oct 10, 2015 10:42 AM
YoloSapien
Sep 25, 2015 07:12 AM
one73ronin
23
Sep 22, 2015 09:56 AM
