R56 Cooling fan sound...but from the rear??
Old Dec 28, 2013 | 07:05 PM
speedbird_1's Avatar
speedbird_1
After getting home today, I noticed a new noise coming from behind the right-rear wheel. I've never heard this sound before, and it was remotely like the sound of a cooling fan on a computer...But cooling what? I know what the fuel pump sounds like when it's priming, as well as the radiator fan and the EPS fan. I've searched around other forums to no avail. And the fan shut off before I could locate the source.
Does anyone have the slightest clue what it could possibly be?
Old Dec 30, 2013 | 10:42 AM
PParker74's Avatar
PParker74
Is you Mini a S? Mine makes the same noise. Im not 100% sure but I believe it is a electric pump that moves the coolant around in the car until it cools off because of the turbo. Hope this helps.
Old May 14, 2014 | 11:52 PM
jkg2010's Avatar
jkg2010
I've correlated this sound (coming from the same area) to when my fuel level is low, but never figured out what it was exactly ...
Old May 15, 2014 | 12:01 AM
Systemlord's Avatar
Systemlord
Same here, before I gassed up yesterday I heard that sound in the right rear. I only had maybe 1.5 gallons left, I was walking around my car when I heard it. I've heard that sound many times before, it must be some kind of fuel return of pressure relief or something.
Old May 20, 2014 | 11:57 AM
wb123mb's Avatar
wb123mb
If you open up the pass side trunk panel there's some sort of electrical wizardy back there; I always assumed that was the source of the noise. On mine, the noise coincides with the trunk release spontaneously triggering, opening the rear hatch. I'm going to diagnoses it more this soon, I'll put something up if it turns out relevant.
danielbrookes_9
Oct 3, 2015 12:51 PM
David.R53
Sep 1, 2015 06:51 PM
Chippawaguy
Aug 19, 2015 10:59 AM
Red Raven
Aug 11, 2015 04:48 AM
