R56 Moisture or blown head gasket
Old Dec 24, 2013 | 09:58 AM
micromini234's Avatar
micromini234
I just found this in my engine on the cover lid. I took it for 10 min drive to pick up some oil. Any thoughts ?
Sent from phone
Attached Thumbnails Moisture or blown head gasket-image-1324669556.jpg   Moisture or blown head gasket-image-3365038059.jpg
Old Dec 24, 2013 | 10:01 AM
bavmotors's Avatar
bavmotors
How's ur dipstick look? Any overheating at all?
Old Dec 24, 2013 | 10:02 AM
danjreed's Avatar
danjreed
Normal. Check coolant, if ok.. Just drive it. Short winter trips cause this.
Old Dec 24, 2013 | 10:10 AM
micromini234
thanks for the quick reply guys. Coolant look good. It was low but seems to have come back up to wear I marked and I'm very slow leak.
No overheating that I'm aware of and no cels, as well I don't have a coolant temp gauge anymore so I can't see if it's going over.
Sent from phone
Old Dec 24, 2013 | 10:39 AM
mbwicz's Avatar
mbwicz
The cold weather has a bunch of moisture that is absorbed into the crankcase when the engine is shut down. If the car is not driven on longer trips (say 20-30 minutes), then the water will not be boiled off from the oil as it heats up. If the dipstick seems normal, then it is just the moisture from short trips. A nice drive will clean up most of this residue, but I would wipe off what you can get to.
Take a flashlight and look at the top of the transmission under the air inlet tube. If there is a blue/green stain there, then your thermostat may have a leak. You can also take off the expansion tank (one bolt on the radiator support) to see if there is a leak on the tank underneath. You can just twist the tank around, you don't need to drain it to check for a leak. I had leaks in both of these locations.
Have fun,
Mike
Old Dec 26, 2013 | 05:59 PM
afadeev's Avatar
afadeev
A coolant leak out of the thermostat housing (or any of the other usual places) would not cause milkshake condensation on the oil fill cap. Many expensive things can, but lets not jump to conclusions with so little data. For starters, clean the cap and take the car out for a prolonged drive. Anything long enough to get engine to full operating temp.
Then check the oil cap again. If it looks clean - have a beer and relax.
If you see more water+oil condensation, THEN let the forum know and stock-up on stronger drinks.
a
iclancy82
Jan 2, 2021 08:59 PM
3L6
Sep 21, 2015 06:21 PM
Sep 2, 2015 09:05 AM
