FS:: H&R Street Performance shocks/coilovers
H&R Street Performance shocks/coilovers -SOLD
Category: Suspension
Price: $600
Location (Region): NorthWest
I have a lightly used H&R set of struts and springs for sale. The front struts are NEW.
(I had a warranty issue for one of the front struts. I sent both in and they gave me two brand new front struts. Rather than leave the car suspensionless until the warranty claim was resolve, I chose to install a new, even stiffer coilover suspension and sell this setup.)
The rear struts and the springs have about 20,000 miles on them and they are in great shape.
These are used in combination with your stock front and rear top hats (the upper strut mounts).
These will fit any R50, R52 or R53 with the steel rear trailing arms (basically anything prior to R56 except an the original GP).
The ride quality is comfortable but responsive, a bit firmer than stock but still comfortable on long drives. These shocks smooth out the bumps much better the stock MINI sport suspension, while improving on the MINI's go-kart like handling. The sport springs are a bit stiffer than stock, ensuring good car control, and are height adjustable.
These would be an excellent choice for the range from daily driver well beginner to intermediate track use.
This is a $1250 setup brand new.
Description from H&R:
H&R Street Performance Coil Overs are the perfect suspension solution for discerning drivers from daily drivers to serious tuners who can appreciate the awesome handling and superb ride comfort. Each coil over shock is custom valved to work in conjunction with a precision-engineered progressive rate spring, creating a finely tuned suspension system. The fully threaded shock body allows for adjustable vehicle height. This feature helps balance vehicle weight, resulting in a lower center of gravity and improved performance and control
H&R Coil Overs feature an innovative mono-tube gas shock construction. Using premium quality materials, H&R engineers fine-tune each coil over shock with a progressive rate spring to ensure better handling and premium ride comfort for the intended vehicle.
Each vehicle specific coil over has a fully threaded, custom shock allowing for adjustable vehicle height. Vehicle lowering is altered using easy to adjust spring seats. Adjustable lowering accommodates summer and winter conditions and allows you to dial in the perfect ride height to fit your personal style. H&R coil overs are designed for performance, comfort, and durability using only the best components. For those drivers looking for refined suspension and a little German style, look no further than our diverse range of coil over applications.
Sep 17, 2015 09:27 AM
Tires, Wheels & Brakes
Aug 26, 2015 10:28 AM
Aug 26, 2015 10:13 AM
Aug 25, 2015 09:18 AM
