18x8 48 offset on r56 ????
Old Nov 5, 2013 | 07:28 AM
mp5999's Avatar
mp5999
Can I fit a 18x8 with a 48 offset on an r56 without issues ? Car has nm springs ( I think that's like a 1.25 inch drop) ????
Old Nov 6, 2013 | 12:05 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
The wheel is OK but with the suspension drop of that amount you have to find a tire that will not rub.
You can go with a narrow tire and stretch fit it, plus dial in more negative camber to tuck the tire inside the wheel arch. You can dremmel trim the plastic wheel arches wherever they are rubbing.
Or you can go with a tire that has slightly less tall tire diameter like-
215/35-18, like the Sumitomo HTR Z III for #115 each, 300 treadwear, 24" tire diameter.
This might be very close-
Michelin Pilot Super Sport
205/40-18, $181 each, 300 treadwear, 24.5" tire diameter is nearly OEM.
This is a very good street tire, comfortable and handles well. If you roads are bumpy and full of potholes, a 35 series sidewall is going to be very rough riding.
Old Nov 6, 2013 | 04:55 AM
v10climber's Avatar
v10climber
I think you might hit the spring/perch with the wheel/tire. But I don't know for sure.
rtk90
Aug 29, 2019 09:08 AM
schwac2
Jun 14, 2016 04:06 PM
actualsize37
Nov 18, 2015 08:58 AM
newowner
Sep 15, 2015 07:18 AM
