Those damn glazing tail lights!
Old Oct 2, 2013 | 01:36 PM
03.BRG.MCS's Avatar
03.BRG.MCS
How do I get rid of that glazing that turns the lights pretty much white? Instead of buying a new set, I'd rather fix it or tint them with some film for $10. If I end up getting a new set I'm goin LED, which will not be nice to my bank account. So if there is any way to fix it, I'll probably try it. Bought it with the intent to get a new left one in a month or so, but I might as well just replace both since now the other side is gettin a little white. So if you can save me $80 I'll be happy
Old Oct 2, 2013 | 01:55 PM
jonnieoh's Avatar
jonnieoh
Pics?
By "glazing" you mean what?
Is it the cloudy micro-scratches from years of wind and grit abrasion, like headlights are prone to getting? If so, get one of those 3M headlight restoration kits. They do a pretty decent job, if you're not in a hurry, and do it right. The kit really helped our old Subaru and CR-V's headlamp lenses...
http://www.3m.com/product/informatio...ns-Repair.html
Old Oct 3, 2013 | 06:41 PM
03.BRG.MCS's Avatar
03.BRG.MCS
It's with the tail lights, not the head lights. And it's more white than yellow. Seems like on the inside. Pretty much makes the light turn white.
Old Oct 4, 2013 | 08:01 AM
They get a haze inside the taillight : You can either separate ( sealed unit ) , then heat and bake method then, then polish, but some guys could still not get the haze out.
https://www.northamericanmotoring.co...ail-lamps.html
Here are some other options.
The have an enclosed housing. Depends also on what year you have for additional options. I see you have a 2003 03.BRG.MCS so you will just need the -7/2004 ( up to ) lights but here is all the options encase someone is looking for something else.
7/2004- Right Taillight
http://www.ecstuning.com/Search/63217166960/ES174660/
7/2004- Left Taillight
http://www.ecstuning.com/Search/63217166959/ES174659/
-7/2004 Right Taillight
http://www.ecstuning.com/Search/63216935784/ES174491/
-7/2004 Left Taillight
http://www.ecstuning.com/Search/63216935783/ES174490/
We also carry many European Spec OEM rear taillights if you are looking for change.
Another option:
7/2004- Tail Light Euro - Driver (Left)
http://www.ecstuning.com/Search/63217166955/
7/2004- Tail Light Euro - Passenger (Right)
http://www.ecstuning.com/Search/63217166956/
Tail Light Euro - Set
Replace a broken or faded tail light housing : Clear top turn 63217166957 KT
http://www.ecstuning.com/Search/SiteSearch/63217166957KT/
Or...
-7/2004 Euro Taillight / brake light kit . Top brake light is clear and tailight look like below.
http://www.ecstuning.com/Search/63210150980/ES2580923/
And last but not least the Euro Clear Left and right side : -7/2004
Clear Tail Light W/ Bulbs - Driver ( Left ) Part # 63216927585
http://www.ecstuning.com/Search/SiteSearch/63216927585/
and
Clear Tail Light W/ Bulbs - Passenger ( Right ) Part # 63216927586
http://www.ecstuning.com/Search/SiteSearch/63216927586/
Thanks and that gives you some options.
Old Oct 4, 2013 | 12:45 PM
03.BRG.MCS's Avatar
03.BRG.MCS
Thanks ECS! That definitely saves me a good amount of time in research. I'll weigh my options and see what I can go with. For right now, the next job is an oil change.
Old Oct 4, 2013 | 12:52 PM
You are welcome, that gives your pretty much everything from euro to US.
If you never oil filters / kits we have them here:
Oil Filter Kit With O-Ring Part # 11427512446
http://www.ecstuning.com/Search/SiteSearch/11427512446/
Thanks again.
Old Oct 4, 2013 | 01:50 PM
ZippyNH's Avatar
ZippyNH
From what most folks have found, it is the plastic that has become cloudy...either a bad batch of plastic, or maybe a chemical reaction (rain-x can cause some plastics to get cloudy like this)....
Think you can either live with it, or replace them.....
Mb460
Aug 20, 2016 10:39 PM
smarsha11
Aug 24, 2015 06:03 AM
cm.d
Aug 19, 2015 08:51 AM
messyjesse96
Aug 12, 2015 05:51 AM
