R56 Need R56 offset help
I'm looking looking into a set of wheel that would be 17x8 4x100 et24 but I'm kinda scared of that offset.... Anyone know if it'll fit? I'd most likely run a 205/40 on the wheels?
This should help. Original offset is 48mm on the factory Infinity Stream rims I had not sure about yours though.
https://www.northamericanmotoring.co...calculator.php
If your not sure exactly what rims you have you can find them here then research the offset. Rota makes several with a 45mm offset.
http://libraryofmotoring.info/facts/wheels/
