R56 passenger window slower than driver?
Old Sep 16, 2013 | 04:47 PM
Mcameron's Avatar
Mcameron
so ive noticed my passenger window is significantly slower to roll up and down than my driver side window (by ~.5-1 seconds), and it sounds as though its straining slightly....
personally it doesnt bother me....i just dont want the motor to fail or blow a fuse leaving my window stuck open/ closed.
now im almost certain there is an issue, however i thought i would check with y'all and rule out the possibility that its normal for our cars....
also, if anyone has had a similar problem fixed by their dealer, how long did it take them?
Old Sep 16, 2013 | 04:57 PM
Ian Landesman's Avatar
Ian Landesman
My 09 R55 does that. I noticed it when I first bought it used but assumed it was just on the same circuit with a longer wire to the other door. It's been fine a year later and 35K miles later. I'm glad to hear someone else mention it though!
Old Sep 16, 2013 | 05:53 PM
Bob Saget's Avatar
Bob Saget
Just as a precautionary measure, go buy some 100% silicone spray. I used to use this a fix for the same issue on other cars. Spray it down the tracks to lube up and treat the rubber. This will allow the glass to slide smoothly on the rubber and keep it from binding.
Don't use grease as it wears out and also leaves a film on the glass. Silicone actually bonds to and treats the rubber.
Old Sep 16, 2013 | 08:21 PM
LNz04's Avatar
LNz04
I have the same problem. A few times it wouldn't work at all. When that happened I opened and closed the door and it worked again. Pretty sure it's a connection but haven't been motivated enough to take it apart
Old Sep 17, 2013 | 03:35 AM
Beachnmini's Avatar
Beachnmini
I took in my R55 yesterday for passenger window prob and they had to reprogram my car.
Old Sep 17, 2013 | 09:26 AM
Ian Landesman
Correction. My driver's window is slightly behind my passenger. It starts a half second after my passenger and finishes a half second late. Always been that way. It always works though. Not concerned. Sorry you are having issues.
Now I'm left still wondering if it's normal that the windows don't start at the same exact moment. Anybody?
Old Sep 17, 2013 | 01:38 PM
1guru2's Avatar
1guru2
There is a service bulletin out on this. There is a part inside the door that drags on the passenger side window. When I took my wife's 2011 Clubman S in for service I told them about the window as it always squeaked and was slower going up. My SA said there was a bulletin out on that. The tech took about 1.5 hrs. to r&r the defective parts and trim something in the door, as well as reprogram the window function.
You don't mention the model year of your car, but her's was still under warranty. Check with your dealer about this bulletin. Good luck!
sevin
May 2, 2026 06:11 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
minicoclub
Aug 25, 2015 09:07 AM
clintmeister
Aug 12, 2015 11:11 AM
