Traction Control and TPS lights stuck on.
So today I turned on my car and the traction control and TPS lights wouldn't turn off, I checked my tire pressure and it was fine, and the reset button wouldn't work. And the traction control switch wouldn't turn the warning light off
. Plz help.
. Plz help.
ya your going to have it checked...
this might not help you... but I had the BIFECTA lights (TPMS and DSC) dont confuse with the common trifecta (abs, tpms, dsc)
I had mine fixed today after an alignment... as these lights can come on due to bad steering angle sensor.... mine disappeared after I had the alignment done... so I lucked out on thiss coincidence.
there is also a write up somewhere where you can reset the DSC/TPMS where you pull the fuse out then back in.... I can't seem to find it though
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
