Air conditioning clutch engaging intermittently
Old Sep 6, 2013 | 11:06 AM
AlphaFox's Avatar
AlphaFox
Today, on my second drive of the day using the air conditioning, the clutch started sporadically disengaging. The air would go from cold to lukewarm and humid, and the drain on engine power would be gone. Then, it would intermittently re-engage, and act as normal. Right now, with my car in the garage, if I turn the air conditioning on, I can see the compressor engage, and it stays engaged, blowing cold air. Any ideas what was causing this?
Prior to either compressor clutch or clutch coil failure, does either work intermittently or is it a sudden failure?
Old Sep 6, 2013 | 11:11 AM
AZdsrt's Avatar
AZdsrt
You are probably low on freon, or the pressure sensor is failing..
Old Sep 6, 2013 | 11:15 AM
AlphaFox's Avatar
AlphaFox
I added a little bit of R134a three days ago. The A/C now gets cold instead of cool, but this intermittent clutch engagement is new today.
Old Sep 7, 2013 | 06:44 PM
AZdsrt's Avatar
AZdsrt
If you're sure there is enough juice, the next thing I would look at is sensors. Something is telling it when to cycle. When the AC clutch is going bad, it usually quits working altogether. I have seen a clutch go bad and slip, thought somewhat rare.
MiniDan
Sep 3, 2015 04:05 PM
Zettinger
Aug 25, 2015 04:04 PM
Bennyboy
Aug 18, 2015 07:28 AM
Fizzyx
Aug 14, 2015 08:24 PM
