'09 Mini Clubman -How is the bulb on the left rear side marker changed?
Okay, here's how I did it....
In order the get at the bulb the inside wheel well must be moved aside. One can remove the wheel if wanted but it's not necessary. Remove the bottom Torx screw (T20) from the bottom of the back bumper and one speed rivet (phillips head) located near the side lamp that holds the wheel well cover in place. Then pull it sightly open to get to the lamp socket. The socket will pull out with a quarter turn. The replacement bulb is a Sylvania 2821 (3W) for the rear and Sylvania 2825 for the front (5W).
SosoMINI
Nov 22, 2015 03:17 PM
cm.d
Aug 19, 2015 08:51 AM
