Intermittent Sunroof, not the typical grease problem
Old Aug 31, 2013 | 07:14 AM
cd26's Avatar
cd26
I've tried searching all over this forum and all over google, my sunroof works extremely intermittently, when it does work, it works flawlessly. But there is no in-between.
It seems electrical to me.
I replaced the switch 3 times with replacements from a junkyard, and I just replaced the entire sunroof motor with module, as soon as the I installed the new motor the sunroof worked great for about 5 minutes, then completely stopped again.
Any suggestions?! Thanks in advance!
Old Aug 31, 2013 | 11:04 AM
AlexQS's Avatar
AlexQS
I don't know the sunroof system well,... But maybe others could chime in on my logic here.
Sounds like it could be a relay that gets stuck, so I'd check to see if there is a relay in the circuit, then test it (or tap on it lightly with the back of a screw driver). Also could just be a short, check wires at all plugs and connectors, do a continuity check with a multimeter.
Thats my 2cents.... Overpriced I know.
Old Sep 1, 2013 | 05:30 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
What year is your MINI?
Old Sep 1, 2013 | 08:00 AM
cd26's Avatar
cd26
it's a 2003
Old Sep 1, 2013 | 09:10 AM
ZippyNH's Avatar
ZippyNH
Check the grounds?
A bad/high resistance ground can cause failures in motors/etc similar to what you are having...
Maybe some corrosion on them, or a chafed wire.
Old Sep 5, 2013 | 05:31 AM
cd26's Avatar
cd26
well now I'm finding out that if I unplug my battery and my ecu,
and then plug it all back in, my sunroof will work on the next start up until I shut the
car off.
then it stops working again!
Toolman
Jan 20, 2016 06:50 AM
LordOfTheFlies
Oct 19, 2015 05:02 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
Fizzyx
Aug 14, 2015 08:24 PM
