Tire fitting
Old Aug 16, 2013 | 09:41 PM
GHSTmini's Avatar
GHSTmini
Tire fitting
Hello, just curious to know if these tires will fit on my s-winders. Specs seem to be alright but I may be overlooking something.
http://www.tirerack.com/tires/tires....6E4X&tab=Specs
Thanks!
Old Aug 17, 2013 | 06:49 AM
cristo's Avatar
cristo
Alliance Member
The S-Winder is a 16 x 6.5 wheel and a 205/55/16 will fit on it fine.
That tire is a little taller than the stock 195/55/16, but should be ok
unless you're lowered with a heavy load. Many people use 205/55/16,
as well as 205/50/16 (a smidge shorter than stock) instead of the OEM
size since they're a little wider and selection in those two sizes is better
than in the OEM size.
kazyn
Oct 25, 2019 02:34 PM
Mini'mon
Aug 16, 2015 04:15 PM
Edgar78
Aug 15, 2015 05:33 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
