R50/53 Can i buy the roof rack mounting kit only?
Old Aug 12, 2013 | 07:49 AM
imncrxtc's Avatar
imncrxtc
hows it going fellas....is it possible to buy the mounting kit alone for the roof bars?
Old Aug 12, 2013 | 08:09 AM
Hello,
For the factory Gen 1 Roof Rack system. R50 and R53 MINI Cooper.
http://www.ecstuning.com/Search/SiteSearch/82710024992/
You can get:
Install Kit w/ the black caps ( For removal ) Part# 82790136426
http://www.ecstuning.com/Search/SiteSearch/82790136426/
Or
Install Kit w/ the white caps ( For removal ) Part# 82790139366
http://www.ecstuning.com/Search/SiteSearch/82790139366/ES197065/
And here are some other trim and hardware pieces.
MINI Roof Rack Cover For Mounts - Priced Each Part number 82790142904
http://www.ecstuning.com/Search/SiteSearch/82790142904/
Here is just the cover caps priced each.
http://www.ecstuning.com/Search/SiteSearch/82790140916/
Cover Cap For Roof Rack Removal - Black Part # 82790140913
http://www.ecstuning.com/Search/SiteSearch/82790140913/
Thanks and hope that helps.
Old Aug 12, 2013 | 08:26 AM
JAB 67's Avatar
JAB 67
From these pictures it looks like if you buy the entire system you get the installation template (for drilling holes in the roof), which is absolutely necessary; however, with the mounting kits alone it is not clear if the template is included. Is it?
Old Aug 12, 2013 | 08:32 AM
imncrxtc's Avatar
imncrxtc
good point....id like to know as well.
Old Aug 12, 2013 | 08:45 AM
Good question.
Update*
The template comes in the install kits. The mounting hardware is for example people that have lost the hardware or bought it second hand and going to install, will need additional hole saw and test arbor. I was posting all the options for you.
You can also get the test arbor and the hole saw separate from the kit.
Aug 14, 2015 11:11 AM
Aug 13, 2015 12:57 PM
Aug 12, 2015 01:24 PM
