Bucking, stalling problem..SOLVED
Old Aug 9, 2013 | 03:59 PM
SpiderKnight's Avatar
SpiderKnight
Just posting my experience with my MINI so that others will have a resource to draw upon.
Symptoms:
At the day of the incidence, the car experienced mild bucking (alternating low or no power, to normal power) when pulling away from a stop. At first I thought I had tripped the DSC system, because that's what it felt like. However, there was no blinking DSC light or any visible water or mess on the roadway that could cause the wheels to lose traction.
After two more stops, the car stalled. Luckily, it stalled near work so a coworker helped me push the car to the side of the road.
Diagnostics:
I started to check the basic stuff, electrical power, obstruction in the intake, bypass valve, spark plug wires. They all seemed to be OK. NO CODES!!!
At this point, the car would turn over, but not start.
I did notice that the fuel pump was not on. Checked fuses and they seemed to be OK.
Tried the 'Fonzi' method on the gas tank (thanks NAM). That is reaching underneath the car just forward of the rear driver side wheel and banging the heck out of the gas tank.
Sure enough I would get a sick sounding whir of the fuel pump and I was at least able to drive to the nearest garage.
Solution:
New fuel pump and filter and the car was driving normal again.
::Note:: Car has 185k, never had a problem with the fuel pump and never changed the fuel filter
Old Aug 12, 2013 | 07:05 AM
RobertJ's Avatar
RobertJ
Good information. What year and model? Thanks for posting!
rtk90
Aug 29, 2019 09:08 AM
ir0nhid3
Sep 18, 2015 07:52 AM
thebombardier
Sep 15, 2015 02:53 PM
mimaal
Sep 4, 2015 09:09 AM
