Interior/Exterior 2003 Mini Cooper S Aux Mod
Old Jul 24, 2013 | 11:29 AM
Tyler Carl's Avatar
Tyler Carl
Hello Every one, I just got a 2003 MC S and it has a radio with single CD player. I wanted to add an aux or even a bluetooth so i could play music. Any ideas/suggestions on how to go about this.
Old Jul 24, 2013 | 11:47 AM
It was just talked about in another thread but this will give you some options.
If you dont have it already in the glove box or under the toggle bank. Its a very popular upgrade for the Gen 1 MINIs. You will know if you have it or not if you see the aux in. Then using a 3.5mm jack connect to you device. Toggle through to you reach Aux on the screen with the Mode button.
Aux Input Cable Install Set Part number 82110153367
http://www.ecstuning.com/Search/SiteSearch/82110153367/ES194874/
Some people install it right below the toggle bank on the backside plastic cover.
3.5 aux jack. Part number 61122153331
http://www.ecstuning.com/Search/SiteSearch/61122153331/ES2145057/
Another option is the more integrated MINI Official IPod kit. Part Number 65110439432
http://www.ecstuning.com/Search/SiteSearch/65110439432/
Here is the install instructions. Its the previous part number that superseded to the one above.
We have the "Dice" Products also below.
http://www.ecstuning.com/Mini-2003-Cooper-R53-S-Coupe-L4_1.6L_W11B16A/Interior/Sound_System/Auxiliary_Input/
That gives you some options for direct connection.
Old Jul 24, 2013 | 12:05 PM
chrunck's Avatar
chrunck
I highly recommend getting the factory cable. It's a piece of cake to install. I've done one in the removable panel like in the picture above and one in a down tube. The panel was a lot easier.
I then got a bracket that mounts to existing screws on the radio, added a cradle, and had a very good iPod setup. I can't remember where I bought then anymore, though.
SosoMINI
Nov 22, 2015 03:17 PM
joelcseymour
Aug 7, 2015 12:43 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
