03 cooper s connecting rod size??
Old Jul 19, 2013 | 07:48 PM
dezertrat21's Avatar
dezertrat21
I recently had the fault code of P00302. Performed a leak down test and found the rings bad. So i tore the engine down this morning. I started to take measurements on the rod journals and main journals of the crankshaft. The main journals are std. size at 48mm. The big kicker is that the rod bearings are measuring at 46mm. I have googled this and only came up with the link below. I then called a few mini shops in the la area and they didn't know anything of it.
Any help is very appreciated Thanks
http://www.ebay.co.uk/itm/BMW-MINI-A...item3a82cc2edd
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
