steam coming from bottom of radiator
Old Jul 19, 2013 | 11:48 AM
Javskies's Avatar
Javskies
im trying to figure out why there is steam coming out of the bottom passenger side of the radiator where that canister looking thing is. i took a video to show it.. when i lifted the car a lot of water was dripping out of that piece. thanks for the help.
its a little loud so make sure your volume is down lol
Old Jul 19, 2013 | 01:37 PM
The location on the passenger side is the Dryer, I can see water or something like it, but it might be from condensation on the dryer, I cannot see the steam in the video. Do you have a better picture. Is it water or greasy?
#2 is the dryer and its connects to the radiator. You might have a leak there at that connection. Did you run the A/C system and this happened?
A/C Receiver / Drier part number 64506917489
http://www.ecstuning.com/Search/SiteSearch/64506917489/
Those are usually replaced anytime you open and replace something in the A/C system.
Old Jul 22, 2013 | 02:11 PM
Javskies's Avatar
Javskies
Ok so I realized it is only happening when the ac is on so does that mean all I have to do is replace the ac dryer?
Old Jul 23, 2013 | 07:06 AM
I would check exactly where the leak is and confirm its moisture or actual grease/ oil, based on video I was telling you the most likely locations Also to confirm its the condenser or dryer. Is there a pin hole or crack you can see on the dryer or condenser, Also is you A/C working and blowing cold air ?
If you have pictures or a another closer video that would help.
blackie
Jan 18, 2017 09:56 PM
alistaircookie
Oct 8, 2015 10:52 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
Redhotz
R55 :: Clubman Talk (2008+)
Aug 14, 2015 05:29 AM
BernieCoop
12
Aug 12, 2015 07:45 AM
