will these fit?
Old Jul 16, 2013 | 11:43 AM
bmorrow's Avatar
bmorrow
will these fit?
got a tough, for me anyways. I need wheels and tires asap and found a cool set of wheels and tires. the tires are 225/40/18's. the wheels are 44.5 mm offset, 9 inches wide and 158mm back spacing. will they fit?
Old Jul 16, 2013 | 03:08 PM
v10climber's Avatar
v10climber
Are you on stock suspension? I'm guessing they'll hit your springs. 9" is pretty wide for a mini...
Old Jul 16, 2013 | 03:18 PM
bmorrow's Avatar
bmorrow
Yes. Stock suspension
Old Jul 16, 2013 | 03:49 PM
Creeve's Avatar
Creeve
no they won't. too tall, too wide and too much offset
Old Jul 16, 2013 | 04:57 PM
bmorrow's Avatar
bmorrow
Haha basically nothing will fit at all. That's what I figured. Thanks for all your help.
Old Jul 21, 2013 | 11:04 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
The combo you described could fit but it's tall at 25.1" tire diameter.
225/40-18 normally fits wheels 6.5-8.5" wide, too narrow for 9" wide rim for good fitment.
The rims could work with 245/35-18 tires, tire diameter is 24.8" which is still taller than OEM but OK for the 9" rims.
Something seems fishy about your wheel specs.
Offset of 44mm should have a backspace of 172mm.This would reduce clearance from the suspension parts by about 0.5".
OEM backspace is about 150-154mm.
If offset and width are as described the wheel will stick out about 24mm or 0.9" more than OEM
trw92a
Aug 26, 2015 01:47 PM
Aug 25, 2015 07:11 AM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
