R60 Can my CMS successfully tow a jet ski / wave runner?
I know there are many variables to this question. I am fairly certain that simply towing the jet ski isn't probably an issue, but getting in and out of the water is. I know it would depend on the angle of the ramp and the conditions wet vs dry, etc. Obviously an all4 would be better, but alas I'm merely working with a fwd.
I guess what I'm really asking is, has anyone had experience with this? I do not have a hitch, nor any watercraft...just doing some research.
Saw this...makes me think there's hope.
The Countryman should be fine for towing that amount of weight (and even more). The keys are the hitch and the length of the trailer's center beam.
There are several hitches on the market today. IMHO, I would select a hitch that has a very secure mounting system for the CM. You may wish to look at the MINI-FINI hitch system -- one of the beefiest hitches out there. Also, look at MINI-Do-More. Both of these hitches are set up to tow at least 2000lbs+.
Also, try to find a trailer with a longer center beam. You will be able to get your craft into the proper water depth without going as far in the water as the CM in the video. Yes, its a little longer and a little touchier to back up, but it's perfect for those very shallow ramps.
HTH
HTH
There are several hitches on the market today. IMHO, I would select a hitch that has a very secure mounting system for the CM. You may wish to look at the MINI-FINI hitch system -- one of the beefiest hitches out there. Also, look at MINI-Do-More. Both of these hitches are set up to town at least 2000lbs+.
HTH
HTH
I used to water launch a 20 ft catamaran sail boat on steep ramps with my Mini Cooper S....manual tranny. Setup likely weighed approx. 900lbs. Did a great job of it. Got lots of gob-smacked looks from bystanders!
spec35
39
Jun 19, 2017 05:54 PM
vulkandino
Oct 31, 2015 08:29 PM
pkillur
Sep 26, 2015 01:57 PM
