Engine oil for high mileage and high ambient heat
Old Jul 6, 2013 | 12:59 PM
marantz2010's Avatar
marantz2010
Good day all,
Normally I have been running 5W-30 before I moved away from the moderate climate of Seattle. My car is a R53 JCW with a 17% pulley. But now I live in Reno, NV... an area with daily highs of 95+ degrees during the summer and daily lows of 0 degrees in the winter.
I believe I will change my oil again before winter, so let's not focus on the winter. Let's talk about summer oil. It gets hot everyday, I drive during these times, and my car just hit 100k miles. I have been using Royal Purple and change my oil every 5-6k miles or so.
I need to change my oil here soon so I was wondering if any of you would recommend switching from 5W-30 to something thicker (because of the heat) like 5W-40. Please let me know what you would do!
Thanks,
Ryan
Old Jul 6, 2013 | 01:08 PM
ZippyNH's Avatar
ZippyNH
Many euro oils ARE 5w-40 or 0w-40....
So it would be fine...heck it is a recommended weight oil in the r53...
Old Jul 6, 2013 | 01:21 PM
mini on's Avatar
mini on
Mobil 1 0-40 is a recommended oil for the Mini. On the bottle it will say euro formula.
Old Jul 6, 2013 | 01:26 PM
marantz2010
What about 10w-40? Would that be a problem? The low temperature shouldn't ever go below 50 degrees.
Old Jul 6, 2013 | 04:03 PM
ZippyNH's Avatar
ZippyNH
In a full syenthic you will (hopefully) not find many 10w-40 oils....this weight is for older engines with wider tolerances.... I would NOT use a 10w oil in a mini....the builders specify a 5w or 0w and a 40 or 30....mix and match...but the oil galleries and bearings are all SIZED FOR those weights....
Old Jul 6, 2013 | 04:06 PM
marantz2010
Thanks folks! I'll use the 5W-40 for summer use and then switch it up to 0W-30 for winter use. Sound like the best possible way to use these combinations?
Old Jul 6, 2013 | 04:32 PM
markjenn's Avatar
markjenn
I don't think any harm will come from it, but I don't think Mini recommends any 0W oils in the 1st gen cars - my R53 manual says only 5W-30 or 5W-40 for "all climates". I personally wouldn't use a non-recommended lower viscosity - you're more likely to do harm than good. I'd use either of these year-round, or if you want to try and refine things a bit, the 5W-30 in the winter and the 5W-40 in the summer.
I guess I'm saying you're probably overthinking this.
- Mark
Old Jul 6, 2013 | 06:07 PM
AlexQS's Avatar
AlexQS
I've heard this before, 10psi oil pressure per 1000 rpm at normal operating temperature.
-A couple months ago I was asking myself if royal purple, mobile one, or castrol would be best, and what weight. I came across this tech article which explains in great detail this "rule of thumb" that dad had told me long ago.
You might enjoy this:
http://new.minimania.com/article/289..._Misunderstood
Old Jul 6, 2013 | 07:21 PM
marantz2010
I read that article, sounds to me that the 0W for startup would make most sense, and then 40 weight while at operating temperature during the summer. Mobil 1's 0W-40 it is. Then during the winter I'll do maybe a 0W-30 or a 5W-30 depending on how I feel the 0W went.
Old Jul 7, 2013 | 12:50 AM
AlexQS's Avatar
AlexQS
Let me know how you like the 0-40 Mobile-1 full synthetic.
I did consider using that, but decided to go with Castrol full synthetic 5-30
Old Jul 7, 2013 | 06:15 AM
NightFlyR's Avatar
NightFlyR
I switch over from the Mobil 1 0w 40 to the castrol 5w 50,, I am burning less oil, and my car has been running better then ever with 135k on it. Temps have been staying at 188 to 196 in 95+ heat that we have head here on the east coast for a week.
TBRoye
Feb 14, 2021 05:16 AM
TREX
Nov 2, 2019 07:31 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
M7Speed
Aug 6, 2015 01:48 PM
