Will they rub?
Old Jul 6, 2013 | 08:08 AM
Jegati's Avatar
Jegati
Will they rub?
I am replacing the run flats with Continental Extreme Contacts. I have 17" wheels with 40mm offset. The CXC's are sold out across the country in 205/45-17, so after researching previous threads it seem the 215/45-17 will fit except I have not seen any mention of fitting with offset wheels. Anybody with experience on an '06 s standard suspension?
Old Jul 6, 2013 | 08:42 AM
Braminator's Avatar
Braminator
I am running Conti DWS same size on a 43 offset. I think unless you lower it more then 1 inch you should be fine.
Old Jul 6, 2013 | 08:49 AM
drewffff's Avatar
drewffff
Not sure about the offset, but I have had 215 45 17 on stock wheels on 2005 mcs and they worked fine
Old Jul 6, 2013 | 02:10 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
You will be fine using stock suspension.
Also I assume your wheels are 17x7", not wider.
Old Jul 7, 2013 | 12:28 AM
Jegati's Avatar
Jegati
Thanks folks! I am going with the 215's. I will post any problems.
Doc Pain
Mar 10, 2021 04:50 AM
freeman727
Dec 10, 2017 04:00 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
Amberleigh MacIntyre
R55 :: Clubman Talk (2008+)
Nov 11, 2015 11:59 AM
Carwash
Sep 15, 2015 02:02 AM
