Navigation & Audio Iphone5 HOT when running Pandora
Old Jun 26, 2013 | 05:13 PM
Mini-LSE's Avatar
Mini-LSE
Two questions. Is it normal for the Iphone to be real hot when running Pandora w/ mini connected? Is it normal for the Pandora/MiniConnect screen to stay on the entire time it is connected? Does not seem right. When I try to put it top sleep it turns off all together.
Old Jun 26, 2013 | 05:18 PM
SuperGreg's Avatar
SuperGreg
Mine stays on with two sync arrows
Old Jun 26, 2013 | 05:34 PM
Mini-LSE's Avatar
Mini-LSE
Thanks. Does it get hot?
Old Jun 26, 2013 | 05:40 PM
dannyhavok's Avatar
dannyhavok
My Galaxy S2 LTE gets pretty hot when under heavy use (Not with the MINI, but still.)
I wouldn't worry about it.
Here's a discussion the apple forums about the iPhone 5 getting hot.
https://discussions.apple.com/thread...rt=45&tstart=0
Old Jun 26, 2013 | 05:42 PM
SuperGreg's Avatar
SuperGreg
I have a 4s, yes it can get hot
Old Jun 27, 2013 | 04:28 AM
yetti96's Avatar
yetti96
Run streaming audio, GPS and text and your car cant even hold the battery percentage, it will slow how it looses the power but it is really consuming some resources. As it is doing all of this it will make some heat...it happens. If it gets too hot you will actually get a temperature warning and the phone will not function. The metal back on the 5 will seam warmer than the previous glass back of the 4/4s but it is acting as a heat-sink and releasing the heat, whereas the glass was an insulator.
Old Jun 27, 2013 | 04:30 AM
KeyPlayaJim's Avatar
KeyPlayaJim
I don't use Pandora, but my iPhone 4s runs hot when using the Magellan GPS app. If you're using a case, I would suggest removing it when running an app which makes the phone hot for any length of time, to allow it to get rid of as much heat as possible. Heat is the enemy of electronics and can greatly shorten the battery's life.
Sexual Chocolate
Mar 31, 2019 08:02 PM
alistaircookie
Oct 8, 2015 10:52 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
ltjpunk7
Sep 6, 2015 07:32 AM
kyungmanpark
Aug 23, 2015 07:26 PM
