Brake Rotors For 06 Mini Cooper FREE!
I'm guessing rotors would fit other years but specifically came off my 06 MCS.
Only removed them because I changed out pads and wanted to start with a clean rotor surface.
I'm guessing these are near new and are the coated type.
Don't want to throw them away since it'd be such a waste.
I'll take them, where do you live or work?
All four rotors?
Let me know what is a good time for you to pick them up from you.
email for me is -
minihune2000@yahoo.com
All four rotors?
email for me is -
Rennwerkes,
Thanks for the parts.
I checked at the Costco site for 195/55-16 non runflat tires-
If you log in as 2006 MCS
You can order-
Bridgestone - Potenza RE760 Sport (Ultra High Perf Summer tire)
Item #: 524791 $119.99 each, 340 treadwear
Tirerack test result-
http://www.tirerack.com/tires/tests/...y.jsp?ttid=163
If you log in as MINI cooper standard wheels,
you can order-
Michelin - Primacy™ HP (Grand Touring Summer tire)
Item #: 440563 $201.99 each, 240 treadwear
Michelin - Energy™ Saver (Grand Touring Summer tire)
Item #: 478162 $187.99 each
Bridgestone - Potenza G019 Grid (High Perf All Season tire)
Item #: 502798 $105.99 each
460 treadwear
Tirerack test results-
http://www.tirerack.com/tires/tests/...y.jsp?ttid=108
OK for street use and in dry, not as good in wet. Is in closeout.
You can try to ask Costco in person if they will special order for you (limited for certain tire brands)-
Bridgestone Potenza RE970AS (Ultra High Perf All Season tire)
205/55-16 $96 each, 400 treadwear. This size is larger than OEM but will fit OK
If smooth riding and comfort is important with decrease in handling then-
http://www.tirerack.com/images/tires...p422_ci2_l.jpg
Bridgestone ER422 (Grand Touring All Season tire)
195/55-16 $106 each, 480 treadwear
Not available at Costco but good on a budget is-
Kumho Ecsta 4X (Ultra High Perf All Season tire)
195/55-16 $83 each, 420 treadwear
http://www.tirerack.com/tires/tests/...y.jsp?ttid=151
Let me know if you need a good shop to do mount and balance for reasonable price in Sand Island access area.
You can order-
you can order-
460 treadwear
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
jrezzo
Aug 9, 2015 10:32 PM
Aug 7, 2015 05:55 AM
