Coolant leak - Thermostat housing or Water pump?
Old May 30, 2013 | 11:26 AM
scurrygirl's Avatar
scurrygirl
I have a 2009 mini cooper with a small coolant leak near the right front passenger wheel. Any way to tell whether the leak is from the thermostat housing or the water pump? Thanks
Old May 30, 2013 | 12:02 PM
Most likely the water pump, the water pump is on the right side ( passenger ) closest to the wheel . If its leaking on or near the transmission on the driver side its the thermostat.
Water pump sets in the back corner of the engine on the passenger side.
Here is what the water pump look like , look for leaks around it.
http://www.ecstuning.com/Search/SiteSearch/11518604888/
There is a pic of the engine without the water pump installed if that helps. There is a water pipe behind it also that seals into the housing. Check that also, could be leaking near the water pump side.
Water pipe.
http://www.ecstuning.com/Search/SiteSearch/11537589713/ES253291/
Here is the MINI OEM coolant also once you find out the leak.
http://www.ecstuning.com/Search/SiteSearch/82140031133/ES196253/
Thanks and hope that helps.
Old Jun 3, 2013 | 11:15 AM
scurrygirl's Avatar
scurrygirl
Thank you!
Wow! Thanks for all the great info and pics! Very helpful response!!!!
Old Jun 3, 2013 | 12:28 PM
You are welcome. Yep hope that helps.
Cereall
Sep 5, 2019 06:05 PM
durablack
R55 :: Clubman Talk (2008+)
Oct 5, 2015 01:51 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
PSIChocolate
Aug 13, 2015 12:46 PM
kwijmbo
Aug 5, 2015 09:00 PM
