R56 mini cooper
Old May 24, 2013 | 10:29 AM
m1kra5's Avatar
m1kra5
mini cooper
can somebody explain me what is that??seems my mechanic forget to put it back after took it in for some check...is this the reason why my car power is cutting off on hard pulls?
Old May 24, 2013 | 11:03 AM
countryboyshane's Avatar
countryboyshane
Crankcase breather hose heater. It does not cause the problem you're having if the electrical connector is disconnected. If the hose is disconnected, the car will still run fine but you're now sucking in unfiltered air and potentially dirtying up your engine.
Old May 25, 2013 | 02:20 AM
m1kra5's Avatar
m1kra5
my mechanic told me that this is working on mini jcw engine and because i put a jcw engine on it without the jcw ecu the programmed the old ecu like the jcw...but im not sure if this does not infect my engine as there is not the plug and the wire for the connector
Old May 25, 2013 | 06:00 PM
countryboyshane
I really don't understand the big picture here. So you did an engine swap with a JCW engine? If yes, the ECU does have different programming compared to the S model
Old May 25, 2013 | 06:29 PM
Braminator's Avatar
Braminator
How about a picture closer to the part and not from the side.
Old Jun 13, 2013 | 01:49 PM
m1kra5's Avatar
m1kra5
mini
i post a new photo with the part that i dont have complete on my mini and i think that this is causing my mini throtle response and lag i have exactly the same tube and i think something is missing
Old Jun 13, 2013 | 01:53 PM
m1kra5's Avatar
m1kra5
yes i know but both engine models have on the turbo mass high flow intake hose a connector which i dont have and i think it makes my throtlre responding not as fast as before
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
Aug 5, 2015 02:10 PM
