R50/53 Shifting Issue
Shifting Issue
Ok so I am having trouble getting into gear. It is if like there were a wall that I have to push through, just to get it in gear. I assumed it was the clutch but, when I called Mini, they said it would not be the clutch. He mentioned the clutch master/slave cylinder. The Mini Dealership is not close to where I live and I really dont want to drive it that far if it is something I can do myelf. CAn anyone tell me what the symptoms of those two parts failing would be? and, how difficult is it to replace?
Sounds like it could be the shifting lug has seized up.....
If you remove the air box completely you can see this mechanism mounted on top of the transmission with cables attached. Sometimes PB Blaster can free it up, but that would only be temporary fix if that worked.
09R56
Nov 16, 2022 10:49 AM
R50/53 Guidance on selling a 2005 S
Toolman
Jan 20, 2016 06:50 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
