R50/53 Bridgestone, Koni, Stop-Tech, & Alta
Old May 23, 2013 | 04:46 PM
lawjdc's Avatar
lawjdc
Just finished up some mods to my 2005 S. Replaced the slippery all-season tires with Bridgestone RE-11A in 205/55 x 16. It immediately became evident that the tires were better than the suspension, so Koni FSD shocks and an Alta 22mm rear sway bar were added. As the front brakes were worn paper thin, some beautiful drilled Stop-Tech rotors were installed, front and rear, with Red Stuff brake pads.
The car is incredibly well-balanced, but naturally drives entirely different than stock. It understeers slightly upon turn-in when hard cornering, but I can probably dial that out, if I want to, by moving the sway bar to a stiffer setting.
Bottom line is that these mods were definitely worth the increase in expense over dull factory replacement parts!
Old Jun 21, 2013 | 09:57 AM
Pure87's Avatar
Pure87
Which Stop-Tech rotors did you get, cryo-treated or normal? How are they holding up so far? I have some new EBC red pads on some ATE rotors that are pretty much toast now and I'm looking for some performance rotors that are easy on the wallet.
Old Jun 21, 2013 | 11:37 AM
tremperj's Avatar
tremperj
Man, I need to get rid of my YellowStuff pads and go with RedStuff.
Old Jun 21, 2013 | 12:02 PM
ZippyNH's Avatar
ZippyNH
Good to hear you are happy!! Everything involves tradeoffs.....and being happy when done is a great thing!!
Old Jun 21, 2013 | 12:05 PM
ZippyNH's Avatar
ZippyNH
Very different pads.... yellow stuff is mostly a track pad...less grippy...but longer lasting....and the most recent red stuff (key here most recent) is more of a fast street. Kind of a different class of pads....
Old Jun 21, 2013 | 03:38 PM
lawjdc's Avatar
lawjdc
The Stop Tech rotors are SportStop Drilled Rotors. They have been great over the first thousand miles.
http://www.tirerack.com/brakes/brakes.jsp?make=StopTech&model=SportStop+Drilled+R otor&group=Cross-Drilled+Replacement+Rotor&partNum=128.34067L&autoM ake=Mini&autoModel=Cooper+S&autoYear=2005&autoModC lar=
Old Jun 22, 2013 | 05:07 AM
mrbean's Avatar
mrbean
I just picked up a set of stop-tech powerslot rotors from helix. They were very reasonably priced.
Debi's Coop S
Dec 27, 2015 02:35 PM
Debi's Coop S
Oct 3, 2015 07:49 AM
Suspension Products
Oct 1, 2015 11:53 AM
Suspension Products
Oct 1, 2015 11:14 AM
Emnotek
Sep 29, 2015 07:37 AM
