R50/53 TPS / DSC lights.
Old May 19, 2013 | 05:22 PM
heresmymind's Avatar
heresmymind
TPS / DSC lights.
They keep popping on randomly while driving, both at the same time. If I turn the car off and then back on they reset.
I read about the tri-fecta. but wasn't sure on this one.
Would this be a Steering Wheel Sensor or Speed sensor on a wheel?
I also noticed after idling for 5-7 minutes it gets ruff and choppy until i rev it 1-2 times.
-Branden
Old May 19, 2013 | 05:30 PM
Braminator's Avatar
Braminator
Usually the Trifecta lights are caused by the ABS wheels speed sensor.
Old May 19, 2013 | 05:35 PM
heresmymind
I should note, NO ABS light issue, just TPS/DSC
-B
Old May 19, 2013 | 05:41 PM
Braminator's Avatar
Braminator
-B
I would check your tire pressure in all the tires as our years don't have actual TPMS sensors.
Old May 19, 2013 | 05:42 PM
heresmymind
I do have sensors in mine, and all of them were 34lbs cold two days ago when i first started getting the problem. maybe steering wheel angle sensor?
-B
Old May 19, 2013 | 05:45 PM
Braminator's Avatar
Braminator
What year is your MINI?
Old May 19, 2013 | 05:49 PM
heresmymind
I have a 2004, i thought they just did the rotational measure, but when i had tires put on they said I had them in my wheels
-B
Old May 19, 2013 | 05:55 PM
Braminator's Avatar
Braminator
-B
1st gens do not have sensor in the wheels. So they were wrong unless you bought a used set of rims that had sensors in them. So I would bump up the pressure to 36psi and see if that helps.
Peking Duck
Jan 19, 2021 03:17 AM
navybsn
Oct 5, 2018 04:42 PM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
Samhillrocks
Sep 29, 2015 12:55 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
