R50/53 I need to identify a part for replacment
Old May 15, 2013 | 06:29 PM
45BArmorer's Avatar
45BArmorer
I need to replace the plastic bit that covers the interior passenger door pull handle and little speaker. I think its some kind of beazle?
What is the correct term and part number for this?
The car is an early 2006 justa.
Old May 15, 2013 | 06:45 PM
Braminator's Avatar
Braminator
Go onto realoem.com and look it up. It is a bezel. You should be able to order it from ECS.
Old May 15, 2013 | 06:53 PM
Turbo R53's Avatar
Turbo R53
...or check here http://penskeparts.com
Old May 16, 2013 | 01:27 AM
BlwnAway's Avatar
BlwnAway
Right here:
http://www.realoem.com/bmw/showparts...54&hg=51&fg=50
#18, and yes ECS does carry them.
Old May 16, 2013 | 05:57 AM
Yep, #18
We have it. Of course dependent on the trim color and speaker option determines the trim. "HK" is Harman / Kardon .
Here is the list and just match it up to the one you need. If you don't know what one you do have I can help you narrow it down. Posted this in another thread and it helped see all the options for the left and right just in-case someone has the same problem but its the other side.
Passenger side ( Right ) : stock speakers - Non HK:
http://www.ecstuning.com/Search/51417035376/ES99014/
Passenger side ( Right ) : H/K speaker system
http://www.ecstuning.com/Search/51417119248/
Driver Side ( left ) White silver - Non HK:
http://www.ecstuning.com/Search/51417035375/ES99013/
Driver Side ( left ) HK version
http://www.ecstuning.com/Search/51417119247/ES99590/
There is also
Anthracite non HK:
Left Side
http://www.ecstuning.com/Search/51417050891/ES99293/
Right Side
http://www.ecstuning.com/Search/51417050892/ES99294/
Gun metal non HK:
Left
http://www.ecstuning.com/Search/51419124127/
Right
http://www.ecstuning.com/Search/51419124128/
TBRoye
Feb 14, 2021 05:16 AM
eliseo1981
Jan 28, 2021 02:45 PM
kpl
Aug 11, 2015 04:52 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
