R56 2007 mini cooper S exhaust rattle between 2000rpm-3000rpm
Old May 14, 2013 | 07:05 AM
07MiniCopperS's Avatar
07MiniCopperS
I just bought a used 2007 mini cooper s with 83000 miles. I notice that when the car is warmed up and I am driving around 2000 rpm, a large rattle occurs towards the front right. it has an alta cat back on it. For the most part when I let off it goes away or quiets down. I looked underneath the car tapped on the exhaust with a rubber mallet and the only thing that makes noise is the flex pipe, but it is the stainless mesh that is woven over top of it. I tapped around for something loose and am finding nothing. Check engine light is not on. any suggestions?
Old May 14, 2013 | 08:14 AM
Check the metal shields around the front of the exhaust near the down-pipe. Sometimes people remove the nuts to move the shield around when installing a down pipe exhaust.
They don't tighten them back and they can rattle at certain vibrations.
#5 in the front
http://www.ecstuning.com/Search/18307595606/
#19 for the back
http://www.ecstuning.com/Search/11657588556/
Then check the exhaust set up and make sure something in the exhaust is not touching them and rattling.
Also check the top heat insulation near the turbo ( when cool of course ). It can rattle if not bolted down.
#17 in the second pic.
http://www.ecstuning.com/Search/11657595605/
Thanks and hope that helps.
TREX
Nov 2, 2019 07:31 PM
SosoMINI
Nov 22, 2015 03:17 PM
jrezzo
Aug 9, 2015 10:32 PM
sungjk
Aug 5, 2015 08:23 PM
