Drivetrain Putting Car on Jack Stands
Old May 8, 2013 | 07:36 PM
johntotah94's Avatar
johntotah94
There are only 4 lifting points on the car so I don't understand how to put the car on jack stands when you have to use the jack to lift the car. Sorry I am an amateur. I don't think you can jack from the rear because the exhaust goes right through the center. Is there any other jacking points not stated in the manual? Thanks!
Old May 8, 2013 | 08:03 PM
Braminator's Avatar
Braminator
Maybe this will help
http://www.pelicanparts.com/techarti..._Your_MINI.htm
Old May 8, 2013 | 09:38 PM
chrunck's Avatar
chrunck
I usually put a 2x4 between the jack points under the side skirt and jack from there. It seems to work pretty well. I've also jacked on the frame near the front, which also works well provided you find a good spot.
I'm not sure why you started the thread in this subforum. You'd be more likely to get responses in a more general subforum, not the modifications subforum.
Old May 10, 2013 | 05:26 PM
mbwicz's Avatar
mbwicz
What are you working on, how many wheels do you need in the air at once? I normally jack up one side with the front jack pad, then put a jack stand under the front subframe. I usually then just leave the jack in place, with the stand as a safety. You can get a jack stand on the rear subframe, but I don't feel that good about it. I trust my floor jack, and use one of the aluminum inserts in the jack pads.
http://www.ecstuning.com/Mini-2008-C...Pad/ES2603147/
Have fun,
Mike
Old May 11, 2013 | 06:09 AM
cct1's Avatar
cct1
This is what the vast majority of us do. There is a little lip just inside of the frame rail; put the 2x4 a few inches farther down from the front jack point (make sure it's far enough down from the front jack point that you can get your jack in), and slide it in as far as it will go--that lip will stop it from going in too far. The jack points themselves are on the frame rail, as long as your 2 x4 is on it you're good. The bottom line is make sure you slide the 2 x 4 in all the way onto the frame rail, and you want to put the jack more toward the front of the car than the back; that's where all the weight is.
Leaving the jack on the jack point, even with a "safety" jack under the subframe, is less than ideal from a stability standpoint--it's not good for the jack either.
Old May 11, 2013 | 06:34 AM
JAB 67's Avatar
JAB 67
Of interest, Sears used to sell a device that raised the car and placed a jack stand at that same spot. Called 'Lift-N-Secure' or something like that. There must have been liability problems, because it quickly disappeared from their stores and catalogs. But I thought it was the ideal solution to exactly what the OP is describing.
Old May 11, 2013 | 08:40 AM
Fly'n Brick's Avatar
Fly'n Brick
Here's a step by step with pictures from Blimey Cabrio. Scroll down to the April 28th post titled "How a stud lifts a MINI". While you're there, spend some time browsing his blog. There is a lot going on in there with some great ideas from Paul - with pictures.
http://www.blimeycabrio.com/?cat=3&paged=2
maestro39
Oct 27, 2015 02:38 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
