R50/53 Clutch pedal feels crusty
Old May 8, 2013 | 07:09 PM
ieandro's Avatar
ieandro
Hey guys. I'm trying to pinpoint an issue I have with my MCS. My clutch pedal has been feeling crusty. To describe it better, it feels almost sticky at certain points whenever I depress the pedal. It isn't insanely sticky, it just feels like going through a pile of rocks on the way in and on the way out. clutch engages fine .. a bit on the low side.
Some things I thought of would be air in the slave cylinder? I had air in my 94 Toyota Pickup slave cylinder, but the pedal engagement was still smooth - just had to pump enough pressure to engage the clutch. Doesn't seem to be the problem with the MCS since the engagement is still there.
Could it be the throwout bearing?
I don't know if i described it well, but maybe someone with a similar situation before know what i'm talking about?
Old May 8, 2013 | 07:22 PM
ieandro's Avatar
ieandro
Also the tranny makes a noise when clutch is disengaged, but goes away when it is depressing pedal.
Old May 8, 2013 | 07:43 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
crunchy feeling clutch pedals are usually the throw out bearing failing so it's time for a clutch kit.
The Valeo kit with flywheel is a great replacement.
wildwestrider
Dec 27, 2015 08:20 PM
wildwestrider
Sep 4, 2015 06:25 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
Sep 3, 2015 02:06 PM
Suspension Products
Sep 3, 2015 09:41 AM
