R50/53 Xenon and halogen headlights
My Mini is a 2005 S that has the xenon lows beams and halogen high beams. Do either of these bulbs get "tired" and become not as bright! My low beams seem to be really, really white with good light spread. But the high beams cast the old halogen yellowish color. I am sure these have never been changed or replaced.
Thanks all!
Thanks all!
I think your question is whether either type of bulb steadily degrades over time and whether bulbs need to be replaced even if they haven't failed yet. The answer is no.
Really not so different from a standard bulb in your home (excluding fluorescent bulbs). If you see an obvious change, a bulb may be starting to fail but otherwise the light is normally stable through the bulb's life.
Those are the normal colors for those types of bulbs. There are aftermarket halogen bulbs that are slightly brighter or produce a whiter color, but don't expect them to match the xenons.
Ditto, you won't find a true match, there are JDM type bulbs out there that are advertised to be color matched, but these are just tinted bulbs that not only diminish the output of the bulb and the coating just ends up burning off & then the tend to be even yellower & dimmer than a normal bulb. (this may even be what you have)
Your best bet for high beams is just a pair of Sylvania Silver Stars, they'll stay white & give you good visibility.
Xenon's are fine till shortly before death...then s light purplish color shift.
Halogens DO DIM with age...
This is VERY apparent if you have DRL's turned on....the DRL's run the halogens at a lower wattage...running a bit cooler....
over time, while running like this DOES lengthen their life, it DOES make them yellow faster...
The 2005+ Xenons are so good I find I almost NEVER use my highbeams!! Having installed 3M headlight lens covers/protectors within a few days of delivery has kept the lenses PERFECTLY clear...heck the covers are still nearly perfect..best $$ I ever spent for my car...wish my wifes car had them (non-MINI)...I have to polish them regualy..and they are still kinda yellowing with age.
If you doubt it, put a new one in on one side and see how much brighter it is.
Xenons... what ZippyNH says. The only difference is the brand and when they were manufactured. I just changed out my Xenons on my BMW 523i here in Germany. The old Philips 85122s were a little on the bluer side, while the Maxlux 4300Ks are practically white.
As for the high beams, if you are not happy with their brightness, you can opt to swap them out for a set of Xenons (with ballasts), or you can put in something a little higher in wattage. I installed Osram 64217s, which are 65W bulbs vs 55W OEMs. It's about an 18% difference. Don't go any higher. You will either burn out the factory relays, melt the housings from heat, or both.
gar56
Nov 15, 2016 06:41 AM
vulkandino
Oct 31, 2015 08:29 PM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:16 PM
Sep 29, 2015 12:11 PM
