R50/53 replaced door latch.. now window doesn't drop
Old May 4, 2013 | 09:55 AM
uromini's Avatar
uromini
Replaced the door latch yesterday with a good known used latch. Now today I noticed that the drivers window doesn't drop when I open the door anymore.
Any thoughts?
Jelly bean in question..
replaced door latch.. now window doesn't drop-forumrunner_20130504_125433.jpg
Old May 4, 2013 | 10:04 AM
Braminator's Avatar
Braminator
You can try this:
Instructions
  • 1 Insert the keys and turn on the ignition. It does not matter whether you start it or not.
  • 2 Put the window all the way up (if you are able).
  • 3 Press and hold the window switch in the up position for 10 or more seconds. Do this with the door closed.
  • 4 Open the door to make sure the window drops as it should. Close the door to make sure it goes back up again.
ZippyNH's Avatar
ZippyNH
If i remember right, the window can be "reinitalized" by holding the switch in the up postion for 6+ seconds....assuning everything is working right. Think the dealer told me to do this first if i ever had odd windo operation, like no dip.
Old May 4, 2013 | 11:41 AM
uromini's Avatar
uromini
Thanx guys.. will try and report back..
Old May 4, 2013 | 12:35 PM
uromini's Avatar
uromini
Bingo bango.. back in action.. u guys never fail.. thnx again...
Cereall
Sep 5, 2019 06:05 PM
Dec 23, 2015 10:36 AM
danielbrookes_9
Oct 3, 2015 12:51 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
